Provisioning issues samsung for TLS WIFI.
Provisioning issues samsung for TLS. EAP: Client doesn't support configured EAP methods. Any idea?
Works good with iphone. Stop working since new update.
Re: Provisioning issues samsung for TLS WIFI.
What version of Android?  Can you use PEAP?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
running android 4.3.  provisioning works great with iphones so we do not want to keep making new SSID for different device.
In the onboard settings, you can select PEAP or TLS to provision to android devices. If you have TLS selected try PEAP to see if it works for you
Sent from my iPhone
Seth R. Fiermonti
Email: seth@hpe.com
I moved to TTLS and MSCHAPV2 for inner. work good with android.
GLad to hear!
Seth R. Fiermonti
Email: seth@hpe.com
What model of samsung
Thank You,
Troy
Are talking about not working after you updated the Samsung or cppm. There is an issue with some samsung devices that deletes the root certs after you upgrade them and you need to reprovision the device to get the certs
Thank You,
Troy
Trusted Contributor I
Running into this same issue with multiple Samsung devices on 4.3.  Not having this issues with a Nexus 7 on 4.4.  Is the only suggestion to use PEAP?  If so, I don't understand why EAP-TLS would be an option.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
The Compnerd,
I believe PEAP was a troubleshooting step to remove the act of provisioning as the issue, rather than a resolution.  As you know, all Android manufacturers do not handle TLS the same and some are better than others.  Is there a specific Samsung Device and Android version you are having trouble with?
