Public Cert - are SANs required?
Quick Public Cert question:
A customer will be load balancing between clearpass nodes per region.  Each region will be doing zone based DNS for resolution of the address.
If all redirects were pointed to the and not referencing the local host name at all, is there a need to have local server names in the SAN field, or can the same public cert be put on each of the servers without any SANs (or sans SANs if you will! )
Re: Public Cert - are SANs required?
You should get a multi-domain cert with the load-balanced name as the CN and
each server listed as a SAN. Use this cert on each server.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
As an FYI, this is covered in the CPPM PKI-101 TechNote, plus a whole lot of other related data you may want to consider/review. Find it on the support page.
Best Regards
ClearPass Product Manager
