Occasional Contributor I
QuickConnect/onboard issue
I am trying to get Onboard working (actually had it working but then it stopped). I created Onboard a a ca, went through a tech note on how to create a single onboard ssid here, it was working but then now when devices need to reprovision the quickconnect app makes all the way through to the "checking connectivity" point and then times out and states there was a problem connecting to the network. In the ap logs I see entries stating radius reject for station <username><mac> from server Clearpass. and  Dropping the radius packet for station <mac> doing 802.1x, and client <mac> is failed to authenticate. Like I stated it was working with Android and windows clients I went to starting getting ios clients which I was having issues gettting going so I tried the working clients and found that they could not re-provision them selfs.....
Does anybody have any suggetions or know of any log files that I migth be able to get a better idea of what is going on? I have 2 other ssids for guest / staff traffic that do not use the Onboard piece.
clearpass version - 6.3.4 - cp-va-500
ap Instants - ap-105
thanks for any ideas,
Jon
Re: QuickConnect/onboard issue
What is access tracker showing?
Tim Cappalli | Aruba Security
It initially shows it going into a post-provision role, and then after the quick connect client times out it seems to show it go back into the pre-auth role
Are you using EAP-TLS with OCSP ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
So the latest request is sending back a user role? No alert tab or anything?
Yes we have it setup with EAP-TLS with OCSP and EAP PEAP without Fast Reconnect - the defaults when I configured the Onboard service.
Did you added the OCSP link from Onboard CA
Thank you
Victor Fabian
Please post a screenshot of the access tracker request where you are seeing the issue.
first off thanks for the help.
yes It is there. I am seeing the quickconnect client step through the process and after qc toggles the adapter, it comes up, moves to checking connectivity and I noticed that the ssid is  disabled with in the client....
At that point, do you see a request in access tracker? What is the EAP method? EAP-TLS or EAP-PEAP?
