Contributor II
Quickconnect and IAP
Hello
i have quickconnect configured in my IIS and the package is ready, how do i need to configure to redirect the IAP-SSID to quickconnect?
Re: Quickconnect and IAP
These instructions are for Instant 4.0 which allows multiple captive portal profiles. (See page 123 of the Instant 4.0 user guide)
Go to Security > External Captive Portal
Click New
For URL, enter the address to the QuickConnect page.
Then go back and edit the SSID profile and on the security tab, go to the splash page drop-down and select External. Then choose the profile you just created.
Tim Cappalli | Aruba Security
Contributor II
it works with my lap, android and ipad :smileyhappy:
