Frequent Contributor I
RADIUS Auth for management Airwave and Clearpass
how to setup management authentication in Clearpass for Airwave.  Is there a setup or tutorial?
Re: RADIUS Auth for management Airwave and Clearpass
It is setup just like any other radius device EXCEPT Airwave requires that you send back the "
Aruba-Admin-Role" in the enforcement profile in CPPM that matches the desired Admin role of the Airwave user.  Even if you send back a positive reply, if it does not have the Aruba-Admin-Role attribute that matches one in Airwave, it will not work.
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Howto-Airwave-authentication-via-Clearpass/m-p/94090/highlight/true#M6850
This guide is for Radius Auth
https://afp.arubanetworks.com/afp/index.php/How-to:_Airwave_to_authenticate_to_Clearpass_via_RADIUS
Thank You,
Troy
