Radius Attribute on IAP
Hi All,
We need to use Cisco ISE or Microsoft NPS.
The required service-type Radius attribute will be "FRAMED".
It is not possible with actual version, the attribute is "Login"
Can you publish a new IAP version which would make it possible to choose between "Login" or "Framed" service-type Radius ?
Regards
Re: Radius Attribute on IAP
Hi, what are you trying to achieve? Return a user role based on an attribute?
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Good Morning,
No, just use this attribute as requirements (fixed in CISCO ISE - we don't have the choice), optional in NPS)
Regards
Mathieu,
It is not clear to me what you are trying to achieve. Are you authenticating wireless clients or administrators or trying to do something else? What authentication methods do you want to use?
Can you post some configuration? Can you post the error messages that you see?
I'm pretty sure that Instant should work with ISE and NPS, but still it is important to know what feature you want to implement in order to help.
You may contact your Aruba partner or Aruba TAC to find out what is preventing you from doing what you want to do.
You should open a case with Cisco or Microsoft.
Both Login and Framed are fully supported by standard and they should support them.
Tim Cappalli | Aruba Security
