Radius Authentication with Aruba Controller
authentication with External Radius Server is our senerio
radius server return packet to controller with the assigned vlan to the user after authentication process complete
For specific SSID can we handle the vlan assignment by the controller after authentication process complete by the external radius
Kindly advice ASAP
thanks
Ess Lam
Re: Radius Authentication with Aruba Controller
Yes, do you have the Aruba radius dictionary installed?
Tim Cappalli | Aruba Security
thanks for your replay
no , it is not installed yet
how can i find it ?
how this will help me ?
What radius server are you using?
juniper unified access control
is there is any document explaining Aruba radius dictionary ?
You would have to search juniper's website on how to install the Aruba radius dictionary.
The attribute you should return from Juniper UAC to set the user Vlan is "Aruba-User-Vlan"
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
As i explained in first massage i want this senrio for specific ssid , not for all returned attribute from radius server ,how can i manage that ?
Radius server return Vlan ID for all user while in one SSID , i want to assign the vlan id from controller
- you need to load the Aruba radius VSA on the Juniper Device.
Next, you will need to check on the Juniper if the "Aruba-Essid-Name" attribute matches the SSID that you want to deal with.  You will then have to return the "Aruba-User-Vlan" attribute with the VLAN that you want the user to be in.
You cannot accomplish this without loading the Aruba radius VSA into your Juniper radius server.
after installing Aruba radius dictionary in juniper unified Access control there is no option to define user by SSID name i can't make policy or role to return "Aruba-User-Vlan" is there is any idea of How to Assign Vlan from controller while the radius Return Attribute with assigned vlan , i tried to use server group rule but it didn't work kindly Advice
You should contact Juniper for the answers to those questions.  http://kb.juniper.net/InfoCenter/index?page=answers&type=search&searchid=1259419773780&question_box=aruba&cntnt=Knowledge_Base&cntnt=Technical_Documentation
 Maybe someone uses Juniper UAC and can reply here.
