Frequent Contributor I
Radius COA problem between controller and clearpass
I want to use Radius CoA between a controler and Clearpass for disconnect user session with a "Terminate Aruba Session" but it doesn't work.
I have this messge in "acccess tracker"
Status MessageSession-Context-Not-Found
In the controler,
in the RFC Statistics,  all the time the "Disconnect Rej" increment  !!!
in the log of aaa about RFC, i have the message  :
Dec 30 10:36:28 :121031: <DBUG> |authmgr| |aaa| [rc_api.c:1188] Invalid parameters, setting nas_port_type to wireless
Dec 30 10:36:29 :121031: <DBUG> |authmgr| |aaa| [rc_sequence.c:115] seq_num_timeout_handler: Freed 0 entries
Do you have an idea ?
My configuration :
CPPM: RADIUS CoA is enabled and using port 3799.
Controller: RFC3746 server defined in AAA profile. Key matches key specific in device details above.
Regards
Yann
Re: Radius COA problem between controller and clearpass
Yann Dorval,
Please make sure that the nas-ip-address parameter configured on the controller for clearpass matches the ip address defined in ClearPass
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi Cjoseph,
Thanks for your answer :
i have check it
On my controler :
On my CPPM
regards
Yann Dorval,
Not in the RFC 3576 definition.  Check in the Radius Server definition on the controller.
Cjoseph,
I think it's good
Regards
Yann
It's strange because in my Access Tracker -> Accounting -> Networ Detail, i have the good NAS-Port-Type
NAS IP Address:
10.1.8.50:0
NAS Port Type:
Wireless-802.11
regards
Yann
in debug aaa you can see, 2 msg about the NAS port Type
Trusted Contributor I
i don't see the COA server connected to your AAA profile, is it there?
your not doing anything special with your network, i.e. NATing, firewall in between, ...?
hi boneyard,
thanks for your reply, for me it's already connected to my aaa profile, see below ( RFC 3576 server 10.1.8.7).
The CPPM and Clearpass are in the same VLAN, network, IP range,  there are nothing between each.
Regards
Yann
and you can't do an CoA on any session? you have check with a recent session you just logged in with?
only thing i would try then is to reset all shared secrets, so on controller (RFC... and radius server) and on clearpass with an easy one. just to rule out any copy paste / fat finger errors.
after that i would contact TAC (and go through all of the above again first :) ).
