Radius COA problem
This thread has been viewed 21 times
  • 1.  Radius COA problem
    Posted Jun 15, 2018 04:54 AM
    Hey
    Trying to get Radius COA working, but it seems to fail. Getting "No response from network device" for example.
    I have a Clearpass with the IP's 10.16.108.54 (data) and 10.0.0.8 (admin).
    The controller VRRP is 10.0.0.14 and the IPs of the controllers are 10.150.0.3-6.
    Our Cisco in between tells me the following:
    No matching connection for ICMP error message: icmp src admin:10.0.0.14 dst klient:10.16.108.54 (type 3, code 3) on admin interface.  Original IP payload: udp src 10.16.108.54/46798 dst 10.0.0.14/3799.
    This would indicate that the udp/3799 are not available at the 10.0.0.14 vrrp interface. I have tried several combination when enabling COA at device settings in Clearpass and as RFC 3576 server on the controllers.
    Can anyone help me with this one ?
    Thanx.
  • 2.  RE: Radius COA problem
    Posted Jun 15, 2018 06:34 AM
    Did you add the controllers management ips in ClearPass ?
    Make sure that the shared key matches (RADIUS/RFC)
    Sent from Mail for Windows 10
  • 3.  RE: Radius COA problem
    Posted Jun 15, 2018 06:40 AM
    I just found the solution. The NAS ip was inherited, when setting this to individual ip for each controller, everything works.
    I guess when sending COA back to VRRP ip, it cannot handle this, since each controller owns the diffrent session.
