Frequent Contributor II
Radius CoA for Onguard
Hi All,
Is there any need to have radius CoA for Onguard to work.
rana
Re: Radius CoA for Onguard
If you want to change a users role, you'll need a CoA.
Tim
Tim Cappalli | Aruba Security
I just want to change the VLAN,
Means if device is healthy then healthy VLAN, if not then quarantine VLAN.
rana
You may want to use bounce client instead. Some clients don't like having the VLAN changed out from under them.
Tim
Thanks Tim,
I configured Onguard and Its working fine, i am bouncing the client to change the VLAN.
Now I have one question..
I configured posture to check McAfee AV with latest version.. But donno from where clearpass will collect the information weather the AV is latest or not.
rana
They are updated in the background as part of your subscription ID. It is recommended to allow a few revisions back (N-3).
Thanks, got my answer.
rana
