Radius and HTTPS certificate expiring
Hello all,
Our radius server certififate is about to expire. I had some queries please -
1. Whats the recommended way of installing the certififcate please ?
2. Are we expecting any disruption while installing/importing certificate ?
3. How to minimize the risks of disruption please ?
4. Which one do we try the certificate first ( Subcsciber / Publisher ) and how do we know if this process has worked as in certificate has been accepted ?
5. While doing this have any of you experienced any issues ?
Many thanks in advance. Any advise/suggestions will be appriciated.
Re: Radius and HTTPS certificate expiring
Have you reached out to your ClearPass partner?
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
Hi Tim,
I have. Not very sure about their response.
Hence I am looking for some 2nd opinions on this.
