Radius authentication in bridge mode
I was reading this thread http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Radius-authentication-in-bridge-mode/m-p/14241/highlight/true#M6053
and it mentions that the default role should be one of allowall.  Is there any reason for this?  I'm looking at locking down some user roles which are applied to many sites including several where the ssid is bridged.
If the role is anything other than allowall, then what will happen?
ACCP, ACCX #817, ACMP, ACMX #294
Re: Radius authentication in bridge mode
Michael_Clarke wrote:
Michael,
allowall was a troubleshooting step.  It is not mandatory.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Ok, thanks for clarifying Colin.
:smileyhappy:
