Ransomeware detection
Customer is facing issues in their network because clients are affected for ransomeware. can clearpass helps in this scenarion to prevent spereding this into network. please assist.
Re: Ransomeware detection
ClearPass can be used as part of a comprehensive security plan to identify users and control network access. I would work with your partner to design a solution that is best for your environment.
Tim Cappalli | Aruba Security
Hi ,
How can we take this forword, Please suggest
Again, you should speak with a ClearPass Partner to see what specifically can be done to protect his endpoints.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
