Regular Contributor II
Removing guest device limit
Looking to remove a 2 device limit thats configured for guest device registration.  System was configured for us, but looking to make the change ourselves,,, have found the rule specifying the limit, but not sure how to set to unlimited, or if to just remove it?
I am wondering as Staff can connect to the Guest network using their AD creds are treated the same as visitors who register for an account?  Does this 2 device limit apply to both?  Can it be different fro staff, so we can have unlimited for staff, but 2 for guests?  Not sure if its a default global setting regardless of who connects to the guest network.
Re: Removing guest device limit
If you want it to be unlimited you can just remove the rule from the enforcement policy
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks, I did think that, but alwyas good to check before deleting anything!
Just remove that rule.
Tim Cappalli | Aruba Security
