Reporting on guest users
I am using Airwave to monitor/manage my Cisco WLCs.   I want to report on the guest users by userid.
I have tried reporting on all the involved controllers, and on just the anchor controllers, but I cannot find a combination that will show me the userids that the guest user authenticated with at the anchor controller.
Any ideas?
Contributor I
Re: Reporting on guest users
What authentication method are you using for your guest users?  AirWave reports differently based on the auth method.
- Jay
web authentication using the anchor controller's internal database
