Regular Contributor I
Reports outside Insight
I would like to use the auth table form insight db to make reports with an other software (a BI for example), what is the best way to achieve it ?
Thanks for your tips.
Dimitri
Re: Reports outside Insight
Please take a look here:  http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/ClearPass-database-access/m-p/128831/highlight/true#M8784
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Colin, access to the DB is allready ok but know my question is more how to treat the datas. Anyone has done this yet ?
