Required field unavailable on social media login
What can make this message pop ?
i was configuring this again for a demo purpuse but im stuck because im getting this message when i go to the url  of the page with the social media login
On the Office 365
i registered a new APP
Enter the application url
gave it permitions on read directory data and sign in a read user profile
I generated a key (im putting this as the client secret password)
im putting the application id as the client id
Also i checked that my callback url is my webpage url which has the social media login page.
On the clearpass
I created  the service with the service template of the social media login
on the guest i created a weblogin with the cloud identity enable
As far i remenber last time i did it like this and everything worked just fine  i dont know if im missing something i dont remenber
Anyone?
Cheers
Carlos
Alternetworks Corp
Re: Required field unavailable on social media login
Are you actually behind a redirect on the controller?
Tim Cappalli | Aruba Security
Hello Tim
Okay on the instant AP i was redirecting to a guest selft registration page and then i had a link in the guest selft registration page to goes to a login page that had the social media login configured... and that was the problem
I moved this social login to the guest selft registration page like an opiton and now its working fine.
Is there a way to get rid of the locally login and just show the social media option is there?
Alternetworks Corp
You'll have to look at the browser dev tools, find the div and then add hide it.
