Frequent Contributor I
Restrict non-company issued smart devices
We use Clearpass (for RADIUS auth and Guest access) with Aruba controllers.  We use Airwatch to provision company-issued phones.  Is there anyway we can not allow "personal" devices on the network even if the person has domain creds?  We tested onboarding, however, that would require a separate SSID for laptops because the laptops connect (automatically) via machine/user auth and the computers are part of our domain.  Smart devices are not.
Re: Restrict non-company issued smart devices
Tim Cappalli | Aruba Security
not sure I fully understand
Did you add Airwatch to the list of External Context Servers in CPPM? There should be a tech note on MDM integration that can help you with this and/or check out the ClearPass Exchange Recipes.
Once you do this, the Ownership field will be updated in the endpoints repository for endpoints registered in Airwatch.
Zach Jennings
no I havent added Airwatch to the list of context servers.
You'll need to setup the MDM integration before you can use the AirWatch
attributes.
