Contributor I
Return SSID name from Cisco WLC for enforcement decisions
Hi:
Is there any equivalent to the attribute "Radius:Aruba:Aruba-Essid-Name" when using a Cisco WLC?
I'm wanting to use Clearpass to run enforcement on two different SSID's that are on the same Cisco WLC, and I'm looking for a way to differentiate them in the service rules.
Thank you!
Re: Return SSID name from Cisco WLC for enforcement decisions
They don’t provide the name in a standalone VSA but you can use the Airespace-WLAN-ID attribute in your service rules.
Tim Cappalli | Aruba Security
Contributor I
That will work.
Thank you!
