Frequent Contributor II
Role Assignment for 802.1X Authentication
I created SSID "Kerry" to user for 802.1X authentication
There'is not 802.1x Authentication Default Role filed to choose
Re: Role Assignment for 802.1X Authentication
Do you have PEFNG licenses installed?
Tim
Tim Cappalli | Aruba Security
I forgot it !!
Hi, TIM
If i want to return role From clearpass to Aruba controller
What 's attribute that i should config on both clearpass and controller side ? Is it filter-ID on both side
Aruba:Aruba-User-Role
Tim
Hi Tim
I have last 1 question.
Is it possible that user authentication via controller and AD without RADIUS Server ?
I try to test on my lab. There's pop-up on client side for inserting username and password but authentication is failed. For this problem I think, It's because on client support MS-CHAPV2 for authentication but on AD support only GTS
What do you think about this case ? and do you have way out for this problem
WPA2-AES Enterprise requires some sort of radius server.  If you don't want to user an external radius server, you can enable termination, MsChapV2, on your controller in the 802.1x profile and change the server group in your AAA profile to "Default" which should have the internal database.  You can then authenticate via 802.1x to users in the internal database on the controller...
