Role assignment for android devices
I am trying to restrict the bandwidth for android phones on the network. Would anyone know how to assign a role based on the OS Fingerprint for android devices only. The controller is running with OS 6.3.1.15
Re: Role assignment for android devices
Do you have ClearPass?
Tim
Tim Cappalli | Aruba Security
No.. I dont have clearpass, but I found a doc which is helpful and will try it out..
Thanks for the quick response
http://community.arubanetworks.com/aruba/attachments/aruba/Aruba-VRDs/26/2/ArubaOS%20DHCP%20Fingerprinting.pdf
I set these ones for a customer a while ago, which seemed to catch all of them.
dhcp-option equals 37012103060f1c333a3b set role  mobile Android
dhcp-option equals 37012103060f1a1c333a3b set role mobile Android
dhcp-option equals 3c6468637063642d352e352e36 set role mobile Android
ACCP, ACCX #817, ACMP, ACMX #294
Thanks Michael.. i got this set and it worked well.
Immi
