Role mapping function in lab but not in production
I re-worked my role mapping in my lab where I have 3 services with 3 separate role mappings. All is good.
This is a Clearpass Guest w/ Cisco WLC (server-initiated) setup.
Initial mac-auth occurs, users is given a "pre-auth" role on CPPM.
User processes portal, is marked known, COA occurs, user comes back into the same mac auth service but is given back the same pre-auth role and not the proper role for me to push the "ACK ACL" to the controller..
I have gone through the configuration up and down to make sure it matches, service rules, policies, profiles, etc..
Is there something I might not be checking and I should...
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
Re: Role mapping function in lab but not in production
You generally don't want to use a role mapping for a session like attribute as it will be cached.
Tim Cappalli | Aruba Security
Yes makes sense...
Hmm so I'm at a loss because in the lab this all works just fine.
the webauth modifies certain attributes on the endpoint which I check against on the next mac auth..
ACDX #420 | ACMP
