SCCM Integration with Clearpass
I hadn't seen anything on the forums, so I figured I would post my setup/use case
We are a higher education campus, with about ~1500 BYOD, as well as ~2500 Coporate owned devices. We used to use Bradford Networks as our NAC, and we would be forced to manually register all our devices, and it was tiring, espically when we recieved our shipments.
On Campus, we used JAMF for all our MACS, and SCCM for all our PCs. Clearpass has endpoint context server for JAMF, however, we wanted to integrate with SCCM, which was not as straight forward. Below are the general steps I followed to get CPPM to integrate successfully with SCCM, and pull devices in.
1: Have a populated SCCM Database
This isn't going to work well unless you have devices in SCCM. SCCM automatically gets the MAC address' of the devices that it manages. CPPM will be running a query against it's database to get that information.
2: Create a user account in the SCCM database server, with read rights.
We created a special account with only read rights to the database. This is the account that clearpass will use when it logs in.
3: Allow the IP address through the firewall
This might not be needed in your enviornment, however, in ours we needed to open the firewall on the database server, to let clearpass IP address through.
4: Configure an Authentication Source in Clearpass:
 Give it a name that you'll remember, and select "Generic SQL Database"
For the next page, fill in your appropiate server information. Make sure the server name you put in is DNS resolveable, (Or use the IP address), but it needs to be the SQL SERVER not the SCCM server. In our enviornment they were diffirent. Enter in the database name you used during setup, and the username and password you created in step 2. Select mssql as the driver.
The Hardest part for me was finding out the sql query to run. The Query is as follows:
select MAX(System_System_OU_Name_ARR.System_OU_Name0) as 'Organizational Unit',System_MAC_Addres_ARR.MAC_Addresses0, Resource_Names0 as 'Host Name' from System_System_OU_Name_ARR left join
System_MAC_Addres_ARR on System_System_OU_Name_ARR.Itemkey = System_MAC_Addres_ARR.ItemKey
left join System_Resource_N_ARR on System_System_OU_Name_ARR.ItemKey = System_Resource_N_ARR.ItemKey
where MAC_Addresses0 = '%{Connection:Client-Mac-Address-Colon}'
group by System_Resource_N_ARR.Resource_Names0,System_OU_Name0,System_MAC_Addres_ARR.MAC_Addresses0;
This Query looks up the MAC address of the device, the OU it belongs too, and the hostname configured for that device. We have it setup so that certain OUs get certain VLANS, and the radius:ietf username gets updated with the hostname.
Last part of this page is to fill in the attributes fetched. I have the following ones returned.
MAC_Addresses0     SCCM_MAC string
Organizational Unit    SCCM_OU string       attribute
Host name                  SCCM_Hostname     attribute
Hit save a few times, add the authentication source to your service, and you should be able to start using SCCM_MAC, SCCM_OU, SCCM_Hostname in your enforcment policies.
The Biggest issues we ran into were with the firewall issues I mentioned above, and the way the username has to be entered when adding the authentication source. We used a domain account to login, and the username had to be entered in the domain\user format.
I am writting this from memory, so I apologize if I missed something while your following this guide. If you guys have any questions/comments please let me know. I'll be happy to lend any help I can.
MVP
Re: SCCM Integration with Clearpass
This is great content! Thanks for sharing.
