Regular Contributor I
SMS Gateway for Clearpass
Hello community,
we have configured SMS authentication for our Clearpass 6.7. So far everything works without problems, we are currently using the cloud service Bulk SMS.
We would like to use our own modem with SIM card as SMS gateway. Unfortunately I found neither a recommendation nor any instructions.
Can anyone recommend an SMS gateway (own modem), does anyone have instructions or a concrete example of how to connect such a modem?
Thank you so much.
Re: SMS Gateway for Clearpass
This is not supported directly with ClearPass.
Tim Cappalli | Aruba Security
but I think it is possible to use a modem or a gateway with http or snmp api right?
Yes, you can.
does anyone have experience with an own gateway or instructions I can use http or snmp to the gateway?
MVP
Instructions for http? That all depends on the API for your gateway. In Clearpass you create a SMS Gateway with Custom HTTP handler.
Here you enter the parameters as your gateway require it to be. The simplest you can make is something like this service-URL
http://ip.or.fqdn/smsGW?text=@MESSAGE@
If it requires some authentication:
http://ip.or.fqdn/smsGW?username=@USERNAME@&password=@PASSWORD@&text=@MESSAGE@
Just test this yourself first in a browser and it shouldn't be a problem.
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
