SMS over SMTP works on CPPM but not on CPGuest
Hi all,
I added google SMTP server on ClearPass Policy Manager with the right credentials and added google certificate on the trust list then I tested sending an SMS and it's working 100%.
Then I added an SMS Gateway (SMS over SMTP) on ClearPass Guest but it's not working.
When I send in CPGuest, I get "SMS was sent to XXXXXX" but i didn't recive anything. I checked the Event Viewer but couldn't find any error.
Any idea what could be the problem?
Re: SMS over SMTP works on CPPM but not on CPGuest
Look in the Application Log in Guest.
Tim Cappalli | Aruba Security
No errors on Application Log.
just SMS was sent to XXXXXXX.
Best to open a TAC case. It will be difficult to troubleshoot here.
