Contributor I
SNMP MIB for CPPM 6.5
I'm trying to find the MIB for 6.5 but can't seem to find it on the support site. Any pointers please?
Re: SNMP MIB for CPPM 6.5
Contributor I
Great, thanks.
Occasional Contributor I
I just went to the link referenced above and pulled down the MIBs but they have a ".my" extention.
Not sure what to do with these?
Trusted Contributor I
do with them what you do with any MIB file, probably import it in your management tool, the extension shouldn't really matter.
