SSID ip issue
one SSID is giving IP address to Laptop but Users  Mobile  other Devices are not getting Ip address
Re: SSID ip issue
Need some more information.
- What type of authentication/encryption is the SSID using?
- Are you using an upstream DHCP server?
- Can you turn on user-debugging for one of the mobile devices?  (logging level debugging user-debug <mac>)
- What user role are you assigning to the users?
- show rights <user-role>
Tim Cappalli | Aruba Security
Re: SSID ip issue
i am using pre shaerd key(WPA- 2) for authentication .
user will be getting ip address from the DHCP.
how i can turn on user-debugging for this?
Re: SSID ip issue
config t
logging level debugging network proc dhcp
After the client associates, do "show log network 50"
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
