SSID with PSK can be enable onguard and force policy from ClearPass ?
  • 1.  SSID with PSK can be enable onguard and force policy from ClearPass ?
    Posted Jul 25, 2018 05:16 AM
    SSID with PSK can be enable onguard and force policy from ClearPass ? Kindly help suggest me, I'm newbie on Aruba ClearPass
  • 2.  RE: SSID with PSK can be enable onguard and force policy from ClearPass ?
    Posted Jul 25, 2018 06:52 AM
    Yes, you can. Please work with you ClearPass partner.
  • 3.  RE: SSID with PSK can be enable onguard and force policy from ClearPass ?
    Posted Jul 25, 2018 06:58 AM
    Hi Cappalli,
    Thank you for your answer.
    Actually, I have consult with local distributor
    However, they said can be support only SSID that using 802.1x
    So, that why I would like to confirm from here as well.
  • 4.  RE: SSID with PSK can be enable onguard and force policy from ClearPass ?
    Posted Jul 25, 2018 07:01 AM
    No, that's not correct.
  • 5.  RE: SSID with PSK can be enable onguard and force policy from ClearPass ?
    Posted Jul 25, 2018 07:12 AM
    Hi Cappalli,
    Thank you for your answer, I will check with our distri again.
