Searching for a solution to sync ipads with airwatch (best practice)
How I want it to work when we have new ipads to first connect to our Airwatch (mdm) server to get profile and perhaps cert to be authenticated to wifi.
First connection with new ipad they have to get a role with rights to communicate to mdm servers to get down profile for wifi and certs. After the profile and certs are downloaded to the ipad they should get one new role on the same ssid that is authenticated.
Hope I have explain my issue and can get one good answer on this. Maybe anyone have done this and have one easy solution? I'm want to have one ssid for this.
Re: Searching for a solution to sync ipads with airwatch (best practice)
Do you have ClearPass?
No Clearpass.
We use windows radius for computers and psk for ipads today. Our mdm tool airwatch ar new and we are looking for the best solution to do this.
