Occasional Contributor I
Selecting for Clearpass RADIUS Attributes
In clearpass, I am trying to figure out who connected to a certain AP within a timeframe. I've figured out that I can use the Radius:Aruba:Aruba-Location-Id attribute to do so, but what I can't seem to figure out is how I can use that attribute to hone in on the data.
The first thing I tried was using the Called-Station-ID, but that's currently configured to send the controller's MAC Address.
I've also tried to do a data filter in clearpass, but I don't see a way to do it for that Aruba specific attribute.
Any suggestions?
Re: Selecting for Clearpass RADIUS Attributes
You can't search for it in access tracker. You can, however, search for it in the endpoints repository.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
Since I don't know which endpoints I'm looking for, I don't think that will solve the problem.
Is there a way then to export the access tracker data? I've tried looking through the exportable logs, but i didn't see any which logged the RADIUS request attributes.
