Contributor II
Self-registration using SMTP to SMS gateway
Hi ,
I am not sure if this is possible but what we want to test is to use an smtp to sms gateway to send the users self-registration credentials sms.
So basically the self-registration portal will require the users Name, Surname, Company and mobile number and then send the self-registration receipt to an email address that is formulated from the mobile number field and a predetermined email domain i.e 0776612341234@email.com
Can any one advise if it is possible and if so how?
Many thanks
Andy
Re: Self-registration using SMTP to SMS gateway
This is all built in to ClearPass Guest. Take a look at page 348 in the CPG 6.3 User Manual.
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=12979
Tim Cappalli | Aruba Security
Contributor II
I kind of figured it was but not sure what to do to make it work.
First enable the mobile carriers you want to list under:
      Guest | Administration » SMS Services » Mobile Carriers
In your guest registration form, enable (or add) the "visitor_carrier" field and make sure it is visible.
Then enable (or add) the "auto_send_sms" field and make the sure the initial value is set to 1.
Under configuration » SMS Receipt, match the fields:
     Phone Number Field: visitor_phone
     Auto-Send Field: auto_send_sms
If you want to customize the SMS receipt text, modify the "SMS Receipt" template under Configuration » Print Templates.
Aruba
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Custom-field-self-enrolment/m-p/119745#M7995
Thank You,
Troy
Contributor II
thanks cappalli and tarnold this looks like the stuff i was looking for.
Contributor II
Another question,
I assume the text "NUMBER" in the email address get replaced by the text in the visitor_phone field in the SMS template and send via the mail server in the messaging setup on the plocy manager.
Contributor II
It works and I am so happy now as hopefully the customer will finally throw his "ICE" server in the trash
:smileyvery-happy:
