Occasional Contributor I
Single SSID for two types of authenction
The intention is to use IAP and CPPM. We will only use two SSIDs, one for the Guest and other one for the Employee. Majority of Employee SSID devices will be mixed supporting all major OS supporting 802.1X/EAP. Few employee devices (Tools) will not support 802.1X. The maximum they support is WPA-2 PSK. Is it possible to use single "Employee" SSID to support both types of authentications (802.1X and WPA2-PSK)? If yes, how these (tools) can be forced to only reach certain URL's.
Re: Single SSID for two types of authenction
No. 802.1X cannot be used with other authentication methods on the same SSID.
Tim
Tim Cappalli | Aruba Security
Those two types of encryption cannot be mixed on the sender SSID.
Colin Joseph
Aruba Customer Engineering
