Social Media Tips #2 SQL auth sorce
  • 1.  Social Media Tips #2 SQL auth sorce
    Posted Aug 19, 2014 02:40 AM
    You will need to create a Genric SQL. I later releases it will be already included in CPPM.
    For you non SQL savy guys I attached the source prebuilt.
    Go to Configuration » Authentication » Sources and click import. The password for when you import the auth source is aruba123
    You will need to change the appadmin password to match your cppm.
    Generic SQL Authentication Source:
    SELECT tag_value AS User_Password
    FROM tips_endpoint_tag_mappings
    JOIN tips_tag_values ON (tips_endpoint_tag_mappings.tag_value_id = tips_tag_values.id)
    WHERE tips_endpoint_tag_mappings.instance_id =
        (SELECT id
         FROM tips_endpoints
         WHERE mac_address = LOWER('%{Connection:Client-Mac-Address-NoDelim}'))
             AND tips_tag_values.tag_id =
                 (SELECT id
                  FROM tips_tag_definitions
                  WHERE name = 'social_password'
                      AND entity_id =
                          (SELECT id
                           FROM tips_dic_internal
                           WHERE dic_prefix = 'Endpoint'));
    Enforcement Policies: (Endpoint:social_vip EQUALS 1) OAuth VIP users (Endpoint:social_vip NOT_EQUALS 1) OAuth normal users
    When adding a new filter to the above Authentication source with the query below and assign attribute name 'SP to Alias Name "SocialSP", you can user this in a role mapping policy.
    SELECT tag_value AS SP
        (SELECT id
         FROM tips_endpoints
                 (SELECT id
                  WHERE name = 'social_method'
                      AND entity_id =
                          (SELECT id
    Attachment(s)
    zip
    GuestSocialAuthSource.zip   1 KB 1 version
