Sponsor Code in Clearpass guest
I have this requirement from user. I understand that in normal guest flow, sponsorship approval will required guest to input the sponsorship email/sms so that approval will be sent to sponsor to approve. Upon approval, guest will then be allowed.
Instead of sponsorship email/sms, are we able to create some kind of sponsor code in Clearpass guest? This code will then be passed to the guest for registeration. Upon registeration at the guest page, guest will just need to enter this sponsor code with their email, and they will be given access.
I am trying to see if we can create different sponsor code for different guest at different events.
Re: Sponsor Code in Clearpass guest
Hi Thanks!
Its seem that I will still have to manually create guest first to generate the code.
We are looking more towards automation where admin will just create the sponsor code themself. Pass this sponsor code to the guest. Guest will still have to self register themself but with a additional validated field in the list "sponsor code"
