- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Spreadsheet for rapid HPE, Aruba-S, Cisco, Juniper, and Extreme, wired 802.1x deployments
3 weeks ago
All,
It's been a while since I posted on here and I wanted to share a way to rapdily deploy wired 802.1x across various platforms:
https://github.com/chronot1995/wired-802.1x-spreadsheet
This spreadsheet that will allow you to copy and paste the relelvant RADIUS / TACACS+ / ClearPass information to deploy a uniform configuration to hundreds, even thousands, of switches.
As a caveat to the above, the first place to check for any 802.1x manufacturer configurations should be the ASE website:
https://ase.arubanetworks.com/
I hope the spreadsheet helps - thanks!
-Mike
AMFX #5
The spreadsheet will help deploy wired 802.1X on Cisco, Juniper, Extreme, an HPE, and Aruba-S platforms
To get started, fill out the "Start Here" tab. On this tab, you can fill out the following information:
- ClearPass / Radius Server IP addresses
- RADIUS / TACACS+ Shared Secret
- RADIUS / TACACS+ Source VLAN
- RADIUS / TACACS+ Source IP address
- Interface ranges for Cisco and Juniper configurations
The data that you enter here will populate throughout the tabs of the spreadsheet. You can then select the platform and copy and paste the relevant data into the manufacturer switch of choice.
The "Advanced Cisco Switch Config" tab provides the following:
- The commands for a wired Guest Portal Redirection
- Advanced Device Sensor configuration for IOS 15+
The "Cisco Switch Config" code has been tested on IOS 12.2.55-SE5 - IOS 15.1
The "Juniper EX Config" code has been tested on JUNOS 12.x - JUNOS 15.x
The "HPE Provision Config" has been tested on legacy Provision and ArubaOS-Switch 16.x images
The "Aruba S-Series Config" was tested through Aruba S-Series code 7.4.x
The "Extreme EXOS 15- Config" was tested on Extreme EXOS 15 and 14, hence the "-" minus sign
The "Extreme EXOS 16+ Config" was tested on Extreme EXOS 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Spreadsheet for rapid HPE, Aruba-S, Cisco, Juniper, and Extreme, wired 802.1x deployments
2 weeks ago
Cheers
James
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
