Frequent Contributor I
Static IP for Guest Access Device
I have an iPad like device that needs to connect to the Guest network.  I have a 3400 controller with Amigopod (Clearpass) for guest access.  I am using the controller for DHCP (172.30.1.x) for guest IP's.  Is there a way for this device to wirelessly connect to our guest network and I assign a static IP?
Re: Static IP for Guest Access Device
You cannot have DHCP reservations when using the Aruba controller for DHCP.  If you use a different DHCP server you can accomplish this.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
ok thanks!
