Still confused with multiple SAN entries for cert
Hello all,
Here is my scenario: I have a production Clearpass server and will be adding another using a VIP. I need to order a new 3rd party cert that references both servers. When creating the CSR do I need to reference the VIP FQDN and IP or just Server1 and Server2 FQDN and IP's?
For example:
CN: cppm.xxx.com
SAN:DNS:cppm01.xxx.com,DNS:cppm02.xxx.com,IP:10.17.2.31,IP:10.17.2.32
or like this with the VIP in the SAN:
CN: cppm.xxx.com
SAN:DNS:cppm.xxx.com,DNS:cppm01.xxx.com,DNS:cppm02.xxx.com,IP:10.17.2.30,IP:10.17.2.31,IP:10.17.2.32
Hope that makes sense, thanks for your help.
Re: Still confused with multiple SAN entries for cert
If you redirect by IP then you should add the IPs but most do not. They would point to the URL.
For a two server you can just put the 3 FDQNs in the SAN entry.
Thank You,
Troy
Sorry forgot to add
Server 1 FDQN
Server 2 FDQN
VIP FDQN
Thank You,
Troy
Couple other notes.
1. There is a cert 101 doc on the support site.
2. Most 3rd party CA have SAN certs that usually have them in a 5 SAN entry bundle. I would fill in all 5 so you dont have to reissue the certs if you add any additional CPPMs.
Thank You,
Troy
Thank you for the input. We redirect via URL so I'll drop the IP's.
Moderator
Todd,
Please do read my TechNote on CPPM PKI 101.... it covers your  usecase and a lot more.
CPPM - Certificates 101 Technote V1.0 .pdf
Best Regards
-d
ClearPass Product Manager
