Contributor I
Strange OnConnect error: "OnConnect enforcement skipped for x.x.x.x - Not a master node"
I'm trying to set up OnConnect with CPPM, and I keep getting an error in the event viewer "OnConnect enforcement skipped for x.x.x.x - Not a master node" where x.x.x.x is the IP of the switch I'm using for testing.  This is error is encountered on the publisher only.  I have the switch configured to talk to the publisher only.  The request doesn't make it to the access tracker.  Any thoughts?
I'm using CPPM  6.6.2.86786 and a Cisco 2960S running  15.2(2a)E1.
MVP
Re: Strange OnConnect error: "OnConnect enforcement skipped for x.x.x.x - Not a master node&quo
Probably a very silly question, but have you enabled OnConnect as master in the server manager?
The log you show suggests it is not..
Also after you changed settings in OnConnect, it sometimes suggests to restart the 'System auxiliary services'. You may try to do that as well once more.
Also make sure you are at a recent version, I would advise 6.6.2 as an absolute minimum, but better use 6.6.4 if possible. OnConnect is new in 6.6.0 and new features and some fixes came out in the patches.
If that does not resolve your problem, I would ask your Aruba partner, or if you are a partner contact Aruba TAC.
Contributor I
Re: Strange OnConnect error: "OnConnect enforcement skipped for x.x.x.x - Not a master node&amp
Ha!  That was the problem.  Thanks very much!
The documentation I have (a PDF from my SE called 'OnConnect_Guide') omits that step.
