Super Contributor II
Strange licensing warning
Browsing through the event log on our cppm cluster ( as you do) and I noticed a licensing warning as shown below. Problem is our cluster has a combined license count of 70K ( CPPM 6.6.8 ). This looks as if 1 server is bleating (<m we do have a combination of 5K and 25 K hardware and virtual appliances. No idea which server it was, haven't got that info. Wea at ~2am so guess it was during some housekeeping chores
PolicyManager exceeded its license capacity. License count=5000, license usage count=8668 endpoints
Re: Strange licensing warning
Looks like the 5K appliance has had more than 5K endpoints in 1 day.
Cheers
James
Does it matter when there's a cluster license ?
Before 6.7 there was a total capacity number for the cluster but there still is an appliance/VMs capacity for each.
The core lic are not shared cluster wide. Only feature lic. Onboard, on guard, guest. As of 6.7 access lic are now shared cluster wide.
Thank You,
Troy
o.k. fair enough. Got an upgrade to 6.7.1 scheduled for 22nd March
Rgds
A
