Swap Space Below Major Thresh
received a SNMP alert marked as Major for all the clearpass in the cluster (10 servers). what exactly is this? is this something that I should be concern? 'Swap Space Below Major Thresh'
Re: Swap Space Below Major Thresh
Yes, it is a cause for concern.  I would open a case with TAC to see where you are and what can be done.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
