Switch between users abnormal behavior in authentication
Hi
When an authenticated user through CPPM press "switch-user" in the PC shutdown options, then the PC will authenticate again "machine and user auth" so the PC port will be assigned to the quarantine-VLAN for a while then again to the data-VLAN after user logs in again.
As a result the original user opened sessions will be disconnected.
So is this a normal behaviour, that authentication will be repeated when doing switch user? and how we can keep the original user opened sessions?
Mahmoud
Mahmoud
Re: Switch between users abnormal behavior in authentication
Is this wired or wireless authentication?
Its Wired
Mahmoud
Yes that's normal. You'd have to do machine only authentication if you don't want it to change.
Tim Cappalli | Aruba Security
