Frequent Contributor II
Switch management access for AD user through CPPM radius
I want to achieve network switch authententication using AD user credential through CPPM radius.
While user request for switch authentication AD will only pass authenticated message to CPPM. In cppm we have group of floders as per different rights(Admin, Read only, Network L1 access). Authenticated User will get access as per the group.
Can some one please share KB url
Thank You..
Re: Switch management access for AD user through CPPM radius
Follow below article
https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-authenticate-Management-users-of-Mobility-Access-Switch/ta-p/187650
Pavan
If my post addresses your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Hi Pavan,
I am looking for Radius authentication not Tacacs.
Instead of TACAS enforcement service use Radius enforcemnet service and try send proper role in enforcment profile.
Pavan
Pavan
What may help is check the videos on this page: https://community.arubanetworks.com/t5/Security/Aruba-ClearPass-Workshop-Video-series/td-p/291597
And then more specific the Admin Access section:
Those videos have examples for both TACACS+ and RADIUS for Admin access, and may help you to get started with your own switch access (if different than Provision/ArubaOS Switches).
