Symbol 7522 AP integration with Clearpass for Guest Managament
Hi
I am working with POC for one of the customer is Symbol 7522 AP integration with Clearpass to implement the Guest Management
I have configured policy rule in CPPM and Radius and login portal configured in Symbol 7522
When i hitting the SSID guest in AP, it is taking to clearpass portal IP but the webpage is not openend.
Expecting solution for the same from anyone
