Frequent Contributor II
TACACS access for cisco devices
Hi Folks,
I am trying to enable TACACS access for Some cisco devices (Switch, WLC, Firewall) Using Clearpass.
Below is the screenshot of enforcement profile.
In above pic you can see that privileged level is 15 and CiscoWLC:Common-role1-ALL.
I am little bit confused which one I actually need, the privileged one or this CiscoWLC:Common or both.
rana
Re: TACACS access for cisco devices
Take a look at this ASE solution:
https://ase.arubanetworks.com/solutions/id/80
Tim Cappalli | Aruba Security
I checked and there only privileged level is configured.
so that means privileged level is required, rest of the things arenot mandatory ..
rana
