Regular Contributor I
TACACS+ and ACS v4
I can configure TACASC+ in ACS v4?
Currently I have it configured, but it does not works.
Re: TACACS+ and ACS v4
Is this a question or comment.
You will need to provide a lot more information.
Device
Name
Firmware
errors in device
CPPM
Version
screen shots of errors in access tracker
ETC.
TACACS
Commands
ETC....
Thank You,
Troy
The conf in Controller:
aaa server-group "TACACS-SVR-GROUP"
auth-server TACACS-SERVER-A
aaa authentication-server tacacs "TACACS-SERVER-A"
host "X.X.X.X"
key XXXXXXXXXXXXX
tcp-port 4949
session-authorization
aaa authentication mgmt
enable
aaa tacacs-accounting server-group TACACS-SVR-GROUP mode enable command all
The error in ACS:
service denied - service=aruba protocol=common
Moderator
If you're stuck with TACACS+, a valid alternative might be using RADIUS. You can download Aruba VSAs for ACS from this link:
http://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/EntryId/115/Default.aspx
Regards
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
What add value?
Moderator
If you want administration access you need to pass back to the controller the following: Aruba-Admin-Role = root
Samuel Pérez
