Frequent Contributor I
TLS connection failed
Hi!
I´m seeing some logging in my arubaos switches:
00469 ssl: AM1: User :TLS connection failed for WEB-UI
session from x.x.x.x due to cipher mismatch
Models: 2530,2920 and 5400r.
We´re running 802.1x / mac-auth / profiling with captive portal with clearpass 6.7.3. The captive portal is http with a landing page containing https links.
What does this error imply ?
/Daniel
ACMP | ACCP | HP ATP - FlexNetwork Solutions
Contributor I
Re: TLS connection failed
could this be a failed login attempt to the web interface of the switch itself?
Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE
