TLS session error, Error 215, Wired Workstation
Dear All,
We are facing an issue with some users authentication with wired DOT1X every day and that what we found till now.
These users they shutdown there workstation at the end of the day (not like other users who lock only then it will go to sleep by GPO).
When they come in the next day and they switch on their workstation we can see on clearpass a denied machine authentication request with error number 215 (MAC_AUTH: No password in request. Not attempting MAC authentication
TLS session reuse error) then they login with their credentials but the request will not reach clearpass then they have logoff the login again then they are ok and connected.
appreciate the help.
Amro
