Tacacs with CPPM for cisco routers and switches
Hi ,
Im configuring CPPM for tacacs authentication with cisco routers and switches.
LDAP is configured under authentication.
Device is configured under Network.
What are the other steps for authentication and authorization ?
Regards
Nimmi
Frequent Contributor II
Re: Tacacs with CPPM for cisco routers and switches
you'll need a service with role mapping or enforcement policy mapping the users to the right TACACS roles and the configuration on the cisco devices.
also check this solution:
https://ase.arubanetworks.com/solutions/id/80
reference post:
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Configuring-TACACS-on-ClearPass-for-Cisco-switches/td-p/206921
