Contributor I
Test Radius Authentication with Command PLease HElp!!
Im trying to run a command that tests radius authentication. I have command(see below) but this does not seem to work on aruba controllers. Does anyone know a more recent command that i can use to test radius authentication??
Example below. thanks in advanced for anyone who can help me with this.
test access radius-server address user username password password secret secret <authentication-port port> <retry number> <source-address address> <timeout number
Regular Contributor I
Re: Test Radius Authentication with Command PLease HElp!!
Try this:
 #aaa test-server mschapv2 <Server_Name> <Username> <password>
Fill in the <fields>
-ELiasz
ACDX, ACCP, CISSP, CWNA
Contributor I
We actually can't test that way because we are using certifcates to authenticate.
Well that makes sense. The only thing this will tell you is if the server is reachable. If it only accept certs, you will get Authentication Failed when you test, but at least you know it responds. If you get a Authentication Timed Out you know there is a connectivity issue.
I'm not sure how you could test authentication using certs from the commandline.
-ELiasz
