MVP
Ticket limit for captive portal
I suppose the limit  of the tickets you can create in the captive portal is 4000 as that the user db limit is 4000...
Alternetworks Corp
MVP
Re: Ticket limit for captive portal
Well its the database which is 4000 i already saw it on another tread...
Alternetworks Corp
Retired Employee
Can you provide a link here to the thread you saw the solution on?
Thank you!
MVP
[ Edited ]
There you go
http://community.arubanetworks.com/t5/Branch-WLAN-and-Remote-Access/One-device-at-a-time-with-same-username-and-password/td-p/30148
Here is an older one
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/How-many-user-admit-the-internal-database/td-p/19810
Is this information incorrect? or did i misunderstood what i read?
Alternetworks Corp
